Hello all,
I have a Pentair MasterTemp 400 heater for my pool/spa. I decided to use it a couple days ago and couldn't get it working. I've done some troubleshooting myself and it's still not working so I have a call in to a local tech. Meanwhile, I thought I'd check in with the experts here to see if I could get some advice.
When I initially tried to turn on the heater, everything sounded normal. Blower fan came on, gas flowed and ignited, and heater "worked" for a few seconds, then shut down with error code E05. I was able to look that up and discovered it was a problem with the flue stack sensor, so I replaced it.
After replacing the flue stack sensor, I tried to get the heater working again, but, again, no joy. This time, the heater progressed as before, gas ignited, it ran for a few seconds longer than before, but then shut off with the "service heater" LED on. This time there was no error code.
I will add that when I removed the panel to access the stack flue sensor, I noticed a fair amount of debris in the box, including leaves and acorn shells, indicating some animal had taken up residence at some point. Whatever it was chewed the wires on the sensor which certainly rendered it inoperative. I saved the sensor, thinking I could splice some wire and a couple plugs onto it in case I needed it sometime. The sensor itself looking in pretty good shape.
I cleaned most of the debris out of the box, but there is still a bit lying around on the bottom. I wondered to myself if it would be wise to get the hose out and hose down the inside of the box to clean it out, but stopped short of doing that, thinking I'd do more harm than good with all the electrical connections.
I've scanned the inside of the box from one side and did not notice any loose wires or anything suspicious. I have not removed to the top of the heater to view the main board, nor have I removed the other side panel.
Anyway, any thoughts from the group on what I might try next would be helpful. I'm going to keep the ticket open with the local tech just in case things end up over my head.
Thanks in advance!
Thanks in advance!
