Pentair MasterTemp 400 Heater
JOgletree
3
Texas
Looking for some help regarding pool heater, its a pentair master temp 400. When I turn on heater it sounds like everything starts correctly, induction fan comes on, gas flow, I hear it light and fan comes on and I feel heated exhaust blowing, but the water temp will not heat. I checked the temp reading on heater and it is set to 102, water temp is 57. after an hour of running the water temp is still at 57.
I replaced the temperature sensor but still showing wrong temp so I need to go back and look at that.
its 12,000 gal after 1 hour temp has increased to 78 degrees, years past would only take 45 min to get to 102
I think the heat is cycling on and off about every 3 min. not sure why.
Are you heating the pool or the spa? If the spa, there can be other issues. If the heater is running and water is flowing, it is heating the water in the heat exchanger.
