- Jul 21, 2013
- 65,638
- Plaster
- Pentair Intellichlor IC-60
Pumps are intelliflor variable speed.
What model number?
J20 - connector 2 is the com port not seeing anything in common with the voltage transformer. I am thinking the voltage transformer has to be good since it actuates the pumps and other features.
The transformer puts out three different voltages that power different things on the board.
Some things can work and some things may not.
A malfunctioning device that works can be pulling down the voltage keeping other things from working.
To me it looks like there is some kind of conflict with the com port and manual operations.
That all runs through the board electronic circuitry.
With the com wire from the antenna module on the heater doesn't acutate, with it off the pumps only run a bit then stop.
You have four possible combinations:
- pump and antenna connected to J20 - heater replay does not work
- Pump only connected to J20 - ???
- Antenna only connected to J20 - ??
- Nothing connected to J20 - ??
Or does the heater relay not operate with either of them connected?
I will try taking all the wires off the com port tomorrow and seeing if the pumps run manually. The controller should not require a communications connect to run manually, should it?
Which controller?
The pump should run from its own control panel when the wire is not connected to J20.
