Hi Y'all,
New to the pool equipment repair world, so I've watched a ton a videos, and am trying my best to repair my Mastertemp200 that won't heat. I've already watched 2 dozen videos, and made some progress, but now I'm stuck about what to replace next. Started with replacing the Thermistor, which fixed my "126" error on the eternal LED panel, but then the Service Heater Light came on. Started taking it apart, and found that the AFS light was turning on, and the blower motor was not spinning. I removed the blower motor, and cleaned that sucker out, it was full of while crystal deposits that prevented it from spinning. After cleaning it out, and lubing the motor, the blower seemed to spin with ease, so I put it back and reconnected everything. The afs light still comes on, but the blower comes on and seems to spinning vigorously, so I think I have the blower working as needed. Here's where I'm stuck. Not sure what to check next. Currently, the symptoms are that the AFS light comes on almost immediately, even before the blower starts up. If I bypass the AFS by jumping the connections, the AFS goes off, the blower continues to run, and I hear an audible click about 8 -10 seconds into the startup cycle, but I don't smell any gas, and the heater never seems to come on. What should be the next few things to check? Any advice would be appreciated.
