Ok everybody. Here's the story. Pool heater is about 2 years old and always worked great. I'm usually the person who turns it off and on, but my wife decided to this time. Problem is she decided to close/open the valves that bypass the heater, but didn't do it correctly. So the water was able to flow into the heater, but the valve was closed on the exit side. I wasn't home, but she said there was a pop sound and then she shut overthing off.
When I came home and tested it out, it's gushing water from the bottom of the manifold. I took the manifold off to see if there were any noticeable damage to it or the o-rings. They all look clean/fine, as far as I can tell. I've seen a thread talk about the heat exchanger and if it protrudes .5" or not, and if the pipe ends look clean. Both are true, pipes clean, and they are poking out. The gaskets around the pipes appear fine too.
I also read a post talking about removing the bottom bolt to see if water comes from that, but if its already gushing out of the manifold - i imagine it would come out of there too. Does this sound like the heat exchanger is broke, or the manifold is shot, or something else I haven't read yet? Thanks for your help!
