Hi folks,
Wow, this is a great forum and I have been able to glean lots of good information from all of the various threads. And thanks for all of the good advice.
I am in the process of planning out the wiring for my load center.
Here is my current plan. Any comments or advice is certainly appreciated.
One of my concerns is that maybe I should instead wire the Gas Heater Direct Spark Ignition Circuit to the load side of the Filter Pump relay. Although the heater has a pressure sensor switch that will keep the circuit open when the pump is not on, doing so (wiring to load side of pump relay), would prevent the circuit to close just in case the sensor switch fails. Any thoughts?
