Moved from here.. Pentair landscape light install
Hi, I'm new to TFP and searched the forums for some guidance to being able to control LV lights via the ET system. We have some LV lights installed on the pool columns, but they aren't connected to the ET panel. I think the issue during our install was that there wasn't an available relay for the LV column lights. We were using the ET4 white remote (buttons for spa, cleaner, air blower and lights), but I installed the Screenlogic wireless connection kit yesterday to enable iPhone/iPad control. I did figure out that the electrician connected the spa light as AUX Extra and it can be turned on separately from the interior pool flood lights. I've attached pics of the transformer and ET panel as currently wired.
- Can I use any of the AUX relays or do I need to add a new relay? e.g., could I free up AUX Extra by having the spa light turn on with the interior pool lights and use AUX Extra for the LV column lights?
- I've read posts about connecting the transformer to the ET, but based on the install I have, it isn't clear if I can just run a control wire(s) or if I also need to run the power through the ET panel.
