I self installed the IpH a couple of days ago. The most difficult part was finding a place to mount the canister since I didn't have any more room left on my pad. I got a cement stepping stone and screwed in the canister onto that. But my stupid Dewalt cordless drill kept running out of battery and my extra battery basically wouldn't hold a charge, grrr. A corded drill woulda been better, but I don't have a corded drill. I used the included saddle clamp and drilled in a 1/2" hole before my SWG and after the heater. After mounting the canister and controller, basically plug and play and thankfully everything worked right from the start. I totally understand that there needs to be regular maintenance for the pump head tube and injection check valve. But searching online here, it seems that Pentair changed the check valve from the all black Stenner used in the past. I think it must be another Stenner check valve but unsure what the equivalent Stenner valve is. Anyway, I want to keep an extra check valve and pump head tube around in case of failure and most likely will just change the check valve half yearly or earlier. Yearly for the pump tube per the manual.
I'm still playing with the settings but after one day, the IpH has kept my pH at 7.6. I'm aiming for 7.6-7-7. My plaster pool with a SWG plus negative edge plus laminars plus high fill TA was making me add acid every 2-3 days even with TA at 70 and borates at 50. Adding acid by hand every couple of days wasn't difficult but just wanted a way to help automate everything, as at this point, acid was the only think I was adding consistently. Plus, I wasn't sure who/how acid would be added when I'm on vacation for over a week. If the IPH keeps my pH in check and all I have to do is add acid occasionally to the canister and do some interval maintenance on the IPH, then I would call it an immense success and exactly what I was after. Of course, if it starts acting weird and I get acid leaks everywhere, then maybe not so much success. Only time will tell.
I wish Screenlogic was able to control the IpH, and also wish it came with a pH probe like the Intellichem, but I wasn't going to use the chlorine injector and orb on the Intellichem. Thought it was a waste to spend the extra money on Intellichem for half the function and quite frankly, I'm hoping that once I get the IpH dialed in, I won't have to make much adjustments. Anyway, I'm happy with it so far after 2 days
, I will report back after a couple of weeks.
