- Aug 6, 2018
- 53
- Fiberglass
- Pentair Intellichlor IC-20
When starting my pool after winter, I turned on the pump and there was a clunk and an over current light. I ended up disassembling the motor and found that I cannot even turn the fan end. The impeller itself seems ok. Can you advise my of my next steps?
As an aside, I checked the water temperature that day, it was only 54 degrees. How do I keep the currently clear water to stay that way? I have a small submergible pump I could use to circulate the water if necessary or should I wait till the water warms? When should I start adding chemicals? I assume I should keep the pool uncovered to prevent it from heating up too fast as well.
Lastly, if I can't fix it or have it fixed, does anyone have any recommendations on replacement? Do I need a pump this large and expensive 3 HP or are there others out there that will do the job (quietly as it is near a sitting area) and be fairly economical? I also wonder about the pump sizing because it's feeding a large filter and heater. This pump has lasted about 8 years.
Thank you so much for any info at all.
Doug
Doug
