I just replaced a single speed pentair whisperflo with a intelliflo VSF. I have an easy touch panel, SWG IC40. I've got the intelliflo wired and functioning and the com wires wired to the easy touch. First, do I leave the pump wired through the first relay (like it was with the single speed) in the easy touch or do I run the AC wires direct to the GFI breaker in the easy touch, I've seen on here that's the correct way. When wired on the relay the easy touch and screen logic see the pump as a power failure when it turns off. Second, I set up the Intelliflo in my screen logic config app on my iPhone. The pump is working and I can adjust RPMS in the screen logic app but how do I set a schedule? I see multiple "circuit" options for various RPM but how do I then schedule those RPM times? I'd like to run it at about 1200-1300 rpm for maybe 14 hours then about 2300 rpm for an hour or two for extra skimming and while the Polaris is cleaning (it has its own booster pump). Thanks for any help
