Hi All - new to the forum and about 4 years pool ownership experience.
Three seasons ago I was persuaded to purchase the Pentair IntelliFlo VS SVRS by a pool technician I no longer use because of mistakes that he previously made. I also have installed the Pentair DE FNS Plus 48 with the pump - pictures of the set-up are attached. Plumbing is 1.5" and the pump is about 20/30 feet from the pool. I have two skimmers and a main drain that does not operate properly so everything runs off the skimmers.
Since purchasing the pump I have learned that the SVRS model should have only been used for commercial pools. The SVRS constantly triggers with any pressure build-up using the filter and the pump turns off. I can turn my multi-port valve on reciprocate and run the pump non stop, but once I turn on the filter, the vacuum trigger will engage. This takes some time or depends on how dirty the filter is and how much pressure is being built up. The filter currently runs around 18-20 PSI and the pump will run with the filter for a few hours, but then shut off.
Has anyone had problems like this before? Looking for some advice as I am about to call it quits on this pump and go purchase the Superflo VS and re-plumb my manifold to match.
Thank you!
Thank you!
