My variable flow pump seems to be incorrectly reporting the flowrate in ScreenLogic after a few minutes of operation.
When I first start the pump, it shows a normal ~450-500 watts, 35 GPM and the spa fountain and tanning ledge returns are bubbling normally. However, after a few minutes, the power usage/wattage slowly decays to around 140 watts and the observed flow rate drops off substantially - as observed by those 2 returns barely functioning. The flowrate still shows 35 GPM on ScreenLogic, but the wattage has dropped to a mere 140-ish and the pump motor is very quiet, just barely running.
When I manually increase the flow rate to say 50 gpm, the power usage and observed flow rate (at the 2 returns) increase to about what the 35 gpm flow rate used to look like. As it continues to run a few minutes, the observed flow rate and power usage will start to increase. So I manually back the GPM down about 5 GPM, let it run a few minutes, back it down another 5 GPM, let it run a few minutes. Now I'm back at 40 GPM and power usage and observed water flow seem as expected for 35 GPM and hold constant.
If I back down another 5 GPM to 35 GPM, the power usage again starts to decay to the 140 range, and pump motor runs very slowly as per above.
The workaround I guess is to just run it at 40 GPM and let "40 be the new 35", but isn't this odd behavior?
The only thought I've been able to come up with is that perhaps my pump impeller might have some debris in it, thereby cutting the pump efficiency and observed flowrate.
