Pentair IntelliFlo Pump Corrosion
Blancmik
89
North Florida
Jandy Aquapure 1400
Fellow TFP'ers... need some help.
I have a Pentair IntelliFlo VSF (#011056) pump that was installed in April of 2019 and I'm seeing some pretty significant corrosion on the pump. Should I be concerned about this? If yes, is there something that I can do to prevent/control the corrosion?
You are in Florida. How close to the ocean water? Everything corrodes in Florida.
Doing some additional searching on the forum, sounds like a lack of bonding may be the issue ( Link to Post )... I believe the bonding wire is what I see on the side of the pump (1st photo). Any suggestions on how to test that this is setup correctly? I don't fully understand the bonding vs grounding concept. :-(
Something is causing accelerated corrosion. Maybe a seal leak or possibly stray current.
Disconnect the bond wire and measure the voltage from the pump bond wire lug to the bond wire.
Then reconnect the bond wire.
Reactions: Blancmik
