We have been in the house for 18 months now and this will be our second season with the pool. The IC40 was working just fine up until yesterday. Had 7.0 fc yesterday. Yesterday, the "Cell" light was flashing, which translates to "Inspect Cell". I found some debris on the cell fins on the inlet side and I cleaned it out with water spray from a hose. I put the IC40 back in, got a solid green "Cell" light, and thought everything was good. This morning, the "Cell" light was flashing once again. I took the cell out, looked at it, there was no debris, and so I figured it might need an acid wash. Did a 15 minute acid wash, put it back in, got a green "Cell" light and thought I was good to go. This afternoon, the "Cell" light is flashing again. Definitely nothing in or around the fins. When I hold down the "More" button, it shows 60% usage, so 6,000 hours on this chlorine generator. Since we just bought the house 18 months ago, I have absolutely no idea how old this cell is. Think it is time to replace it. However, finding one of these things online is almost impossible. I cannot find a Pentair Intellichlor IC40 no matter how hard I try. Last summer, they were readily available. Any suggestions?
Is there a different chlorine generator that I can use with my Pentair EasyTouch. I looked at the iChlor briefly and it too appears to be unobtainium and I am not sure it would swap right into the current plumbing I have in place for the IC40. However, if it will work with my EasyTouch, I can deal with the plumbing if need be.
Does Pentair still make the Intellichlor?
