- Apr 20, 2022
- 38
- Fiberglass
I apologize in advance as I imagine this has been asked and answered a thousand times but I could not find an answer after searching the threads.
My setup - 18k saltwater fiberglass pool with Pentair Intellitouch/Screenlogic automation and of course the IC40 salt cell. So recently during my frequent pool chemical tests I noticed that my chlorine levels were steadily going lower and lower. At first I thought perhaps an anomaly due to weather factors or some other issue. I bumped up my chlorine production on the intellichlor to help. Then they dropped to the almost no chlorine level and I realized something must be wrong. I looked at the salt cell and the green flashing inspect cell light was on. First thought was the cell needed cleaning but I just checked it about 2 months ago when I installed new filters in my Pentair CCP filter and it looked good then. Nonetheless I did a cleaning anyway. Very little if any bubbles coming out as expected. Aborted that procedure after less than ten minutes so as not to affect the cell needlessly. I thought perhaps the cell is upset because the chlorine is so low. So first I decided to go old school and just adjust chemicals the way I used to before I could afford the fancy automation. After a couple of days everything was perfect except for the cell not making chlorine of course. Still blinking. I tried shutting down the system at the breaker and restarting. For a while I thought that fixed it. Light stopped blinking and everything seemed normal. When I checked it the next day its back to blinking. Checking the life of the cell showed 20% used before the cleaning. 40% after (ouch! killed it 20% with an unneeded cleaning) The one thing I couldnt check for was phosphates as my chemical kit does not test for that. I have one coming in the mail tomorrow, but I added a couple of bottles of Clorox ClearPhos phosphate remover and after 24hrs still nothing.
Is there a reset that is needed? I've read the manual front to back and cannot find a reset procedure for the IC40. Ive searched here and on the web generally and nothing helpful thus far.
If someone can share some ideas I'd be eternally thankful!
One more thing I should mention - my entire system is going on 3 years old. Currently its probably 2.5 years old. Contractor installed all the equipment and its all Pentair. I was told previously that all the Pentair equipment gets an extended warranty to 3 years because its all Pentair and all professionally installed but I don't know if that extends to the salt cell.
Anyhoo - thanks for any help!
