Tincup
I just swapped out my old mechanical timers for the newest Intellicenter controller. I have the smart app on my phone but would like the PC version of the same software. I remember the old Screen Logic software but can't find anything for the newest controller. I found a test site that showed the application here on these forums so I know it exists. Can someone point me in the right direction?
1. Ensure your IntelliCenter is setup for internet access. If you have questions regarding this step, let me know and I will be happy to walk you through it.
2. Before you can login in to
www.intellicenter.com using the Web App, you need to add a new user account name and email address in the IntelliCenter™ Control System Outdoor Control Panel, located in the Main System Load Center. Navigate to:
Pentair User Portal/Add a New Account. Then, from the Home screen on the Outdoor Control Panel, tap Settings > Pentair User Portal. Then Enable Web & Mobile Interface: Tap this button and select ON.
3. Add New Account: Enter your information, email address, property name and a password. The system will attempt to connect to the owner's account email address (via the
Internet) to
www.intellicenter.com.
4. Now you need to connect to your pool using the Web App: Go to:
www.intellicenter.com and sign in using your email address. Select the your pool listed on the installations screen to display the Home screen.
5. Go to your control panel and ensure you have enabled "
Web and Mobile Interface to ON".
That is the default setting. This enables the Web App and Mobile Interface which allows local network and Internet communications to your home network. I'm going to assume that this is already on, since you indicated that you have connected via the Mobile App.
I really like the new controller but it's major software problem is that there are no pro active notifications to the user. So if the pump fails to run or go into freeze mode protection there is no notification to the user via email or push notifications. They are visable when you access the software but not until then.
There are in-fact "Pro-Active Notifications"
You can configure them in the Web-Client by navigating to: Settings>General Settings>Notifications, once you get the web-client set up.
You can also configure them from the Mobile App by navigating to: Settings>System Configuration>General Settings>Notifications.
Lastly you can configure them from the IntelliCenter Control Panel. See pp45 of the IntelliCenter Control System User's Guide for detailed information regarding
Alerts & Warning.
Let me know if you have any further questions on this and I will be happy to help.
Hope this helps and let me know.
r.
