We had a IntelliBrite 5G Color Underwater LED Pool Light that failed after three years of use.
It seems to be a very common failure, where gradually each color is lost until eventually the light stops working altogether.
We pulled apart the light and investigated what is going wrong, and we discovered that one of the chips that supplies the power to the LEDs overheats and eventually burns out and hence why the LEDs stop working.
We looked at a full Pentair replacement light, but that costs $1,000.
Even if you just replace the Pentair LED board inside the niche, it still costs $600 and it's likely to fail after 2-3 years.
My daughter is a SW & HW engineer, so she set out to design a low cost replacement, and we have just receive the first prototypes from the factory in China.
The design is still under going testing, but the initial testing is looking good.
You basically open the existing Light, remove the existing Pentair LED light PCB and replace it with board below.
It's as easy as undoing four screws, remove the two connectors, and replacing it with the prototype shown below.
