Pentair intellibright white LED - 1 out of 8 not working
johnmastraci
66
Midwest
I have 8 lights, 1 off then is barely lit. The other 7 are fine. 3 year old pool. Pics of the wiring are below. They are wired into a smart switch zwave which has been great. I reset it- no fix. I’d try changing the switch but not sure it’s the switch when 7 out of 8 work.
Any thoughts? Do I just have to replace the one light?
Thanks!
All you can do is replace the light engine in the IntelliBrite or replace the light. Neither is cheap.
Thanks. I’ll have to figure out exactly which LED I have. They are pretty small, smaller than the palm of my hand.
You said you had IntelliBrite but that sounds like MicroBrite.
MicroBrite lights have no serviceable parts.
Globrites are not serviceable either. Your only option is replacement.
With 8 lights, you can either change them as they fail, but if you use other than Globrites, the color sequences, brightness, etc will not be the same for each one. You have nearly $5000 worth of lights. At 3 years, all will fail soon.
Some have used Florida Sunseeker lights as replacements. They use a silicone ring to retain the unit in the Globrite receptacle. Pentair Microbrites also will fit using a similar silicone ring. No reports on if those have longer life.
When were the lights installed?
You may have a 3 year warranty if your Pool Builder properly registered your Pentair bundle warranty.
Every one of the lights had a tool in the box. Amazing.
If you buy a Globrite to replace it, it will come with a tool. otherwise you have to use two screwdrivers or needle nose pliers to engage the notches and turn the light to release it.
