Good Evening All,
A couple days ago I did a chlorine test and my free chlorine was 11ppm. No CC's according to my tests. I had my generator set on 70% output, all lights on cell are green. CYA is currently at 90. Water temp has fluctuated between 85-93 over the past week. Water appeared to be a bit cloudy so added some clarifier. That did clear up the water however chlorine levels have continued to drop even after chlorinator bumped to 100%. Salt level on the pentair app shows 3600. Free chlorine went down to 7 as of Friday AM. Reached out to PB and they sent their maintenance guy out and replaced it with an IC 20 for testing. Set it to 100% and now the chlorine is now at 5. Still no CC's. We have received 1.75 inches of rain here over the weekend. There was swimming yesterday as well for about 4-5 hours. Just seems like even with everything going on my chlorine level should be headed up. Should I leave my pool on overnight to see if my levels go up in the morning? Open to additional suggestions.
Thanks!
Thanks!
