EDITED from original post to correct info.
Just replaced Pentair MasterTemp 400 (10 years old) control board with a new Rev14 Board (part 42002-0007S) that has an LCD instead of LED.
After boot cycle, the LCD shuts off, unlike the LED on the original Rev8 board, which remained on to display inlet temp. With the new board, there are no error codes on the display and no lights on the board itself, but heater does not operate at all.
Questions:
Thanks in advance for any advice...I'm not all that much a handyman and slowly learning as I go, but nearing ready to give up on this one.
Questions:
- Is the LCD supposed to stop displaying after boot?
- Considering the entire manifold assembly is new and no codes/lights, is the new board bad or might there be another trick to this?
- 10 yr old MasterTemp 400 was "warming" not "heating" and finally threw an E01 code. Replaced thermistor, which was definitely bad...physically broken off...(as well as replaced all other sensors on the manifold plus the thermal regulator, as long as I was at it).
- All wiring appears in good condition.
- Re-insert old board and it boots, throws the E01 code. Re-insert new Rev14 board, it boots, LCD shuts down, nothing happens regardless of EasyTemp settings or service mode settings on the panel.
