Pentair Heat pump questions...
Mar 15, 2016
449
Easley, SC
I recently installed a used Pentair Heat Pump HP1200 and have it connected to my automation. I have a few questions if anyone else has this similar model.
When the automation has the main pump and heat pump turned off I get a "Low Water Flow" alarm. Is this normal? I just want to make sure I do not have something wrong? I have the two remote wires from the main board to the automation, and then the automation signals when to turn the heat pump on/off. Just seems like it should not be looking for water flow if the automation has it turned off?
I also noticed it show a Suction Temp. After the heat pump has been off for several days it still shows this temp as 120 degrees. I believe this is the temp of the coils but should they be showing a more accurate temp?
