Hello,
This is my first post, I would like to start by thanking the community for all of the valuable information on these forums!
I am reaching the ending stages of a new pool build and have decided to incorporate a pentair easy touch 4 control system (p/n 520914). In addition to controlling my pump and pool lights, I'm wondering if it would be possible to control a currently unused irrigation system valve to provide a convenient way to add water to the pool. The electrical characteristics of the irrigation valve are as follows:
Assuming the aux valve connections won't be useful, the other obvious option to me is to use one of the aux circuits to switch 24 VAC to the irrigation valve. If this is the best option, can the 24 VAC output supplied by the system transformer be used?
Last question, is there a way to do this without consuming one of the aux circuits?
Thanks for any help offered, I really appreciate it.
David
- Controlled by 24 VAC signal
- Normally closed (when no signal applied, the valve prevents flow)
- To allow flow, 24 VAC is applied
- When 24 VAC is applied, result is in rush current of about 0.45 Amps
- After initial in rush, hold current is about 0.25 Amps
David
