Hello TFPer's! I just moved into a new home in California from Leawood, KS and I have a Pentair Easytouch System with an EasyTouch 8 Wireless handheld controller only - no installed wall unit. The controller seems to be working meaning when the main control panel has "pool light" activated, it is also activated on the handheld. The date, temps are syncing. The problem I have is that when I want to turn off the pool light from the handheld, the device will not respond. After about 30 seconds it says "communication timeout". I've cut power to the main panel, turned off breakers, hit the reset button on the main control panel, resyncd the handheld and it still does not respond. Any ideas?
