On the Screen Logic app, System alert shows “pool solar temp sensor”. I have replaced this sensor. On the Easy Touch panel, I can see the (correct) temp readings from all 3 sensors (Air, Water, and Solar).
But the Screen Logic app (on my iPhone) shows no temperature readings. And it will not allow any comms (start pump, turn on spa heat, etc). All of these functioned properly prior to the solar sensor alert.
In addition to replacing the sensors, I have:
re-set the panel (via the reset function on the panel menu);
Power cycled the panel;
Reset the screen logic interface protocol adapter (including disconnecting/reconnecting the ethernet cable;
Deleted and reinstalled the Screen Logic app on my phone;
Don’t know what else to try. Open to any suggestions.
Thanks in advance!
Jim
Thanks in advance!
Jim
