Hello,
I have done a lot of troubleshooting with my unit and I am a bit stumped as to what is going on.
1. I have all breakers off in the easy touch panel.
2. I turn on easy touch breaker and panel powers up.
3. I turn on filter pump breaker and I am getting power to the pump, and pump runs fine when in service mode, but noticed salt cell is not on.
4. To get my salt cell to come on I need to push the Filter pump button on the easy touch panel, but when I push this button it trips the filter pump breaker.
I immediately thought it has to do something with the salt cell, so I pulled out the volt meter and tested the output from the GFCI breaker to the Transformer, and I am seeing 240v
I then traced it back to the salt cell power board, and I am getting 18v to the power board.
I have tried replacing the Transformer and still seem to be having the tripping issue, and I just recently replaced the Salt cell power board and It did seem to fix the issue, but then a couple of days later, it is tripping again and I do not have a light on the power board.
I have removed the power connector from the salt cell to the power board and it still trips without the cell connected.
Could this be a bad salt cell and the new board it fried again?
