- Oct 8, 2013
- 24
Wanted to turn the water feature on through remote but it was not working. Then I found that the Pentair Easy Touch 8 control panel is out. A service call would cost $125 to start with, ouch! So I'm thinking to give it a shot myself first. Here's what I found:
Thank you for anyone that can help shed some light on this! I can't believe my luck after just replaced the filter ... Pool is a lot more fun when whose turn to brush is the only concern of the day!
- Nothing shown on the display and no lights on for any pump/feature.
- The "12 V ELECTRONICS BLU/WHT" 3AMP circuit breaker is tripped. (See Image 0)
- Reset the CB, and in 1 sec it tripped again.
- There is a light electrical burn smell if I sniff hard
- Valves and relays have their own CB but I unplugged them anyway from the board. Changed a new CB and turned it on. Still nothing on display or lights, but I suddenly sense a stronger electrical burn smell and saw a bit smoke coming out of the middle of the motherboard. Then the CB was tripped again.
- I doubt the communication portal (to the remote control) or the temp sensors are causing the problem. I still plan on undoing those wires and testing the unit but won't count on them to be the culprits.
- The electrical burn makes me wonder if it is a transformer problem. Not sure if it's possible for one (12V) to fail but the other two (18V & 24V) still work. The question here is how do I test the transformer to know whether it is the problem. I read in some posts that people said they read the voltage on those breakers, but I'm not sure how to read that. Two wires go to the breaker, one from the transformer and the other from the motherboard. If I put the electrical meter's two terminals to one wire head each, I don't even get a read on the two working breakers.
