Mark,
I don't see anything obviously wrong with your wiring.
Please tell me which relay you are using for your perimeter lighting...
The first relay is the Pump/Filter relay... It could just be the pics, but it appears you are routing the power to your IntelliFlo through this relay. If so, this is not correct. The IntelliFlo pump should get constant power..
Is your Cleaner run by the IntelliFlo or by the WhisperFlo?
Do you have a pool light? If so, is it controlled by Aux 2
The more you tell us, the better answer you will get.
If you put "Mark" at the beginning of your signature everyone can address you by your real name and not your screen-name.
