I've seen other threads on problems with these actuators, which have been very helpful. One of my actuators, 1.5 years old, is getting stuck and clicking.
I opened it up, and it was fully of greasy gunky water, so clearly leaking somehow. I took the shaft & gears apart, cleaned everything up, and after putting things back together loosely to see if the gears would engage, I can see that one of them has some teeth worn down and needs to be replaced. I ordered the new gear set, and I'm hoping that will solve the problem without replacing whole unit. The motor has some rust on the housing, but appears to work okay.
One problem, though, is when I opened up the gear box, there was a small rubber O-ring, approx 7/16" outer diameter, lying on the bottom. I have no idea where this came from or where it goes, and I'm not seeing any such small O-ring on this exploded view: CVA-24 Valve Actuator (AMS1726): Compool (PENTAIR) | AQUA-MAN - (possibly related - unless I'm missing it, there's no part numbered 6 on the diagram.)
A larger rubber ring goes on the bottom of the shaft, but no idea about the smaller one. I suspect the O-ring and leak may be related. If anyone who has repaired or rebuilt these things knows, I'd appreciate any info. Thanks!
