Pentair CCP520 cartridge?
akhil
65
Irving, Texas
I have Pentair CCP520 cartridge (part no 17-8585). There are 4 cartridge which are not that dirty but I there is very less pressure in the gauge (less than 10). Now I am not sure if water is flowing properly or not.
I need to know if I should but new cartridge or the gauge is broken ( I see few cracks on top of cartridge).
Thanks a lot.
BadDogPSD
146
Reno, NV
CircuPool RJ-60 Plus
How old are the filter cartridges? What is your normal psi? A clogged filter would result in higher than normal pressures.
Jimrahbe
23,131
Bedford, TX
A,
I have the CCP-520 and at 1200 RPM, my filter pressure is less than 2 lbs. and I have plenty of flow..
When filters are dirty, the pressure will go up. This is because the filter pressure is a measure of how hard it is for the pump to push the water through the filter.
As long as you have good flow out of your pool returns, lower back-pressure is better, not worse.
Cartridges should last 8 to 10 years unless you do something stupid, like use floc or clarifier..
akhil
65
Irving, Texas
Thank you for replies. My cartridges are 3 years old and even if I clean the cartridge my pressure is gauge is still low.
Today I clean the cartridge and running the pool at speek of 3000 rpm but gauge is showing less than 10 (20 gallons per minute). Shall I replace the gauge or valve plus gauge?
Jimrahbe
23,131
Bedford, TX
A,
Do you have good flow of water back to your pool or not???
Why do you think that you only have 20 GPM???
Besides looking at the gauge, what is your actual problem? What is not working like you think it should..
JamesW
28,257
In this picture, it looks like the pressure side cleaner line is open, which will bleed off flow that does not go through the filter.
Can you show a picture of the whole system?
Is the filter plumbed correctly?
JamesW
28,257
Cracking cartridges usually indicate backwards flow.
With backwards flow, the pressure will drop as the cartridges get dirty.
Does the line from the pump go to the filter port marked "Inlet"?
JamesW
28,257
This shows how much pressure the filter creates at different flow rates.
For example, the pressure created by the filter at 90 gpm is only 4 psi.
At 44 gpm, it's only 1 psi for the filter plus whatever the heater and plumbing add to the return head loss.
What is the pump model number?
Is the pump basket clean?
Maybe check the pump impeller if the problem persists after you check everything else.
akhil
65
Irving, Texas
A,
I dont see any other issue. Only pressure is less. I cleaned the cartridges and running the pool at speek of 3000 rpm but gauge is showing less than 5
JamesW
28,257
This shows water going through the Jandy energy filter which does not go through the main filter.
You should close the line to the right.
Do you have a picture of the whole system?
