Ok…so my filter is leaking bad at clamp o-ring (invent even run the filter it’s so bad) It’s really weird. I ordered a new o-ring, but in the past, when you put the top on, it more or less rests on the o-ring. Then you clamp down on it. Not so now. It’s like the filter got bigger (impossible) or the o-ring is too skinny. When I put the top on, the two filter halves completely touch. It’s like the o ring isn’t fat enough to cause a seal. I’ve had this filter for over 10 years. This is a first. I’m completely stumped. I’ve looked at all 3 o rings (I have the old ones) and they more or less look the same. What in the actual F…
Has anyone experienced this?
