Ty for information. This is still left. Hopefully it's enough
Ok, your TA is about 10. Try about 15 lb of bicarb.
Have you been filtering?
What filter do you have?
With the ph so low, you need to make sure that the water is not going through anything that could be adversely affected by the acidic water.
BTW - I like your monkeys!
Sent from my iPad using Tapatalk
So when your filter pressure rises 25% above clean pressure, you will want to clean. This may be after just a few days with the particulate visible.
