If I’m using 3/4 inch of foam for the base, do I leave the pavers out of the ground 3/4 inch, to match up with the foam floor?
Can I use just one of that size under each leg? I know you did 2.Yes, you want the pavers flush with the foam. Looks like those pavers should be ok, never really seen anyone use them before. If you look in the masonary supplies aisle you will find the 8x16x4 half blocks at most big box stores.
You would have to get your measurements perfect. The legs kind of start on the front of the pavers and push back as you fill. That's why I worry a little about the octagon pavers, you may end up in the narrowest part when you fill the pool.Can I use just one of that size under each leg? I know you did 2.
HOLY COW THANK YOU THANK YOUYes, you want the pavers flush with the foam. Looks like those pavers should be ok, never really seen anyone use them before. If you look in the masonary supplies aisle you will find the 8x16x4 half blocks at most big box stores.
The legs kick out about a foot beyond the top rail. There should be a layout diagram floating around the forums here, I will see if I can find it. I assembled the top rail to locate the pavers roughly.1 more question.. about how far do they push out?? I am going to set the pool up dry and then dig for the pavers (then i have exact spots, instead of guessing measurements) but how much "flex" should I allow
