Hi all,
I am leveling for a 27' AGP (Saltwater Aurora), and found this in the instructions:
Take material such as rock dust or fine mortar that can conform a solid, permanent base and deposit this material around the rim of the basin. The material used should be spread around the perimeter of the pool to a width of 24” (60cm) and a thickness of 2” (5cm). (Image 8)Note: Bottom rails will be placed in the center of the perimeter of the pool see the dashed line. (Image 8)h. Recheck the outer perimeter of the circle, where the pool wall will be. Compact the ground and make sure there are no high or low spots. The bottom edge of the pool wall must rest flat on the ground and have no gaps under it
Has anyone done this with rock dust/fine mortar? It seems like people just put the pavers in the dirt instead of compacting a special layer.
Regardless of whether I use the rock dust, should I put the pavers on gravel/sand mix or will they be fine countersunk right into the dirt? My soil is very heavy on clay.
For the base, I was thinking of 2" of sand with XPS on top, then an Armor Shield.
Does that sound reasonable? Overkill?
