Hi all,
I bought a house a year ago that has a salt water pool. It persistently gets green algae - mostly on the grout near the surface, all around the pool, even at the skimmer which has a lot of flow, but also patches at the bottom of the walls, corners, steps. It used to brush off quite easily but now I’m getting stubborn patches that won’t brush away.
I have my water tested regularly and it shows perfect chlorine levels, 4ppm. And stabiliser levels are good. The only thing out is the pH is a bit high at 8. The pool shop just suggested turning up my chlorinator but no other advice.
I run my pump around 3000 rpm for one hour, then 2500rpm for 7 hours and I’m based in South Florida so lots of sun. Pool is around 12,000 gallons from my very rough estimation.
This is my first time owning a pool, so is it normal to always have to brush algae away (like daily) or should the chlorine prevent any algae? And how do I tackle the stubborn patches?
Thanks in advance.
Thanks in advance.
