- Jun 24, 2021
- 7,510
- Vinyl
- CircuPool RJ-60
36,600 Gallon Pool in-ground, OHIO.
New to pool ownership. Up until a bad storm, the pool had been fine. Working with local pool store, buying and doing what they told me. After a week with no results (cloudy pool) and constantly fighting my chlorine levels, decided to get edumacated. GLAD TO HAVE FOUND TFP.
CYA = 70...figured out pretty quickly why I'm fighting cloudy pool. Also figured out that I've been pool stored. Have been using Trichlor pucks. No wonder my CYA is so high. Decided that rather than risking SLAM not working at 70, to bite bullet and replace.
Started partial replacement. Poolmath says replace 43% of my water to get CYA to 40. I'm about half-way there (used the calcs to determine to put water in deep end and take from shallow...using pump). All good.
When I'm done with replacement, BEFORE SLAM, what do I need to make sure is right?
a) Ph 7.6-7.8
b) TA 60-80
c) Calcium 50-550
d) Others? Only Ph? Ph and TA?
e) is there some order to add chemicals? Or can I do all at once?
f) how long do I wait after adding to retest?
Thanks for the help!
a) Ph 7.6-7.8
b) TA 60-80
c) Calcium 50-550
