About a year ago we had our indoor pool deck redone and the company dripped their polyurethane product all over the inside of the pool. We had to diamond grind the plaster in order to remove the material. Since that time the plaster on the floor of the pool seems to be deteriorating and there is also a pretty significant crack. The pool has also been more susceptible to algae, especially along the edges of the floor where most of the grinding had to be done.
We received a quote for about $25,000 to replaster the pool and are looking for a less expensive option. I used to paint my residential pool with Super Poxy paint from In The Swim with good results. The paint job was good for 4-5 years and the painted surface was slick, so rarely had any problems with algae and if we did get iot little it was easy to remove. Our pool company said they didn't have a problem with our painting the pool, but said they don't do it anymore and referred me to a company that could do it for us.
Is this a viable/ reasonable option for our indoor pool? Any drawbacks or things to consider? Being indoors, I'm guessing an epoxy paint job may last quite a bit longer than it did in my outdoor residential pool. It is also a bromine pool. Does that make any difference?
Any thoughts or information about painting vs plastering the pool is greatly appreciated. Thanks.
