- Jul 4, 2012
- 749
- Vinyl
- CircuPool RJ-60 Plus
Hey All,
Thought I would share as when I researched this last year I did not find a lot in terms of historical threads on the forum on the topic.
I've never liked the white metal look of the outside of my pool. In past years I had put a bamboo fencing around it, but it eventually got weathered and gross.
So, last summer I decided to give painting a shot. I just used a standard Behr exterior paint/primer in one, 2 coats with a roller. My wife plans to paint a kind of foresty looking scene around it eventually, but this goldish yellow is the base. It survived the winter (including a stretch of -20 we had here!) no problem. The only time that the paint peeled was last summer when an inflatable was left against the wall on a hot day, it pulled a way a bit of the paint, but I just touched it up and that was that.
I did consider scuffing up the exterior with sandpaper to make it stick better, but decided I did not want to risk compromising any outer coating, and as you can see I left the top railing untouched for two reasons - concern that the darker color could make things too hot to the touch, and, far less of a risk of a paint spill into the water, or splashing from water on still wet paint!
Overall, I am very pleased especially given that this only took a couple hours of work.
