- May 23, 2015
- 25,716
- Plaster
- Pentair Intellichlor IC-60
What would be a good brand of synthetic turf?
It's regional and really depends on the local installers in your area. Typical costs can range from $6-$10 per sq ft (or higher for higher end materials). DuPont makes an excellent material called ForeverLawn. SYNLawn is also another distributor that's been around for a long time and they have an extensive product line. But, like most things outdoors, installation is key and you need to have an installer that knows what their doing. Grading the area properly for drainage and using DG to top off and compact the soil is important. Barrier materials may be necessary to avoid weed growth. After the area is prepped, cutting and nailing down the turf so that seams don't show takes a lot of skill. Then there's applying infill material to the turf to give it a realistic look....a quality installer will know all of these steps and guarantee a professional look; some doofus with a truck and a pair of scissors can buy low quality turf from HomeDepot and do a cheap install, but it will show.
Only way to know for sure is to call around for quotes and references.
