So added 64oz of 32% acid and about 2 lb of Dry Strabilizer...
I actually added them by pooring them into the skimmer slowly, instead of the sock thing, i just dont know how to fit about 2lb of this stuf into a sock. Not sure if i messed up
Please don't do that again. I'm assuming you used liquid MA...right? That's way too strong to expose your equipment to almost "undiluted" as it would be going thru the equipment. Its real hard on the gaskets and such.
And dry stabilizer can sometimes get kind of greasy feeling when wet and clog a pipe. Not to mention that putting it in the skimmer means it is now sitting in your filter so you can't backwash for a while if you needed to.
2 pounds of CYA can go into one or two knee socks.... or one that you let dissolve and then repeat.
Maddie
