We have our AGP in a tight spot. On top of that only one end would be OK for the stairs, or the roller.
One long side is close to house, other long side is close to fence.
We're opting to put the solar reel for the blanket on the fence side - this will mean using the 24ft cover length on a 26-27 foot pole - to be determined, measuring with our post hole digger person shortly.
The only other options are to put the reel on the same side as the stairs, back further, and have it clear the 6 feet of stair railings (or to put the roller across the middle of the pool ruining our pool entirely. There's no room for a swing out unless we had it cut in 2 pieces, and I'd rather not mount anything to the pool honestly. Being so close to property/other properties I am wary of adding stress to the pool.)
If anyone's done this either a custom build or a purchased reel with this long a pole can you let me know your thoughts on why / why not for it working?
ALSO - how much clearance do I need? Can my reel/roller sit flush with my pool and just get pulled a bit up and over (assuming longer straps to ensure it sits nicely on the pool) or should it be well over my pool or level with it?
