I went to change the housing on my Polaris booster pump for the pool sweep, and noticed that the pump outlet pipe screwed into the pump housing is metal rather than plastic. This metal pipe is going into plastic on both ends, the pump housing and the pipe fitting. It looks like the pipe might be steel. Is this the correct material to use? Every other pipe is plastic in the pool equipment system. It seems like this metal pipe would be a source of corrosion, but maybe it needs to be metal for strength? I'm not sure..
Let me know your thoughts.
