- Jun 9, 2015
- 62
- Vinyl
- Liquid Chlorine
- CircuPool Edge-40
Looks really green.Those numbers look pretty darn decent...how does the pool look?
You need to use muriatic acid to lower the pH to 7.2 Once the pH is lowered you can begin the SLAM Process.
You would add 65 ounces of 31.45 baume muriatic acid, let it circulate about 30 minutes and test again. The top of the pH scale for most home pool tests is 8.2, so your actual pH might be higher.
OK.. now that you got your chem numbers back in line lets start the SLAM Process to kill the Algae and get your pool crystal clear. I re quoted Zea's post so you know where we are in the process. Add some more MA to get the pH down to 7.2 and start SLAMing away. A SLAM takes a few days depending on how bad the algae is so be patient. The more diligent you are with brushing the nooks and crannies will help the process along. Trust us, you husband will be impressed with the final outcome.Looks really green.
Just go slow. You overdid the baking soda a bit. Now that the numbers are in the correct range, follow the SLAM process (it’s a process) and ask questions, and keep posting results. Chlorine is what gets rid of green pool. So you’ll be adding a lot of it.Looks really green.
Yup, that is the chlorine killing off the algae.. As that happens your CC should be rising. what was your CC reading? Isn't this fun!So this time I only got 11tc. So it went down two in one hour.
No ccYup, that is the chlorine killing off the algae.. As that happens your CC should be rising. what was your CC reading? Isn't this fun!![]()
Make sure you’re testing the right things:No cc
Tested again. it’s at 14.5 tc no cc.
Every time you test, you should add enough chlorine to bring it back up to your SLAM level. You can test less often as your chlorine demands slow down during the process.Do I not need the fc to be 16? It’s at 15 now.
I backwashed this morning before I started adding bleach. The pressure is 35-40. Didn’t think to look to see if it goes to 0 when I turn it off.I've been following your thread. Just wanted to make sure you keep an eye on the pressure gauge on your sand filter. The filter pressures can rise quickly during a slam and may require frequent backwash cycles depending on how high your algae load is. First, make sure your pressure gauge is working, if it does not return to zero when the pump is off then it should be replaced. The gauge itself is usually inexpensive and easy to replace, I usually have to replace mine every couple of years. I'm currently on day four of my slam, my pool was VERY green (swamp) and full of tadpoles and frogs. I'm having to backwash mine every three hours or so. My pressures go from 19 right after a backwash to 25 in about three hours. As the sand gets full of organics it decreased your waterflow through the filter which greatly slows down the progress of your SLAM.
