RoyR
You will have different features on the same pump, the only thing that controls what features are running, are manual or automated valves (if you separate the lines - this is a lot of plumbing).
This manufacturer recommends having valves on the output to each water feature to control the water flow (I did that on mine, also added a bypass - they both seem to work fine)
in addition, in the wall, you will have at least four manual valves to control the flow / set it evenly....see hand drawing attached.
Using the SPA pump, or water feature pump as a spare for the circulation pump is not commonly done...more plumbing. If your pump fails, you can swap the SPA pump, with the circulation pump, or order a new one overnight.
Calculate how much water you need, and select the required pump / plumbing size - if you call PerformancePro (503-356-5888) , they will help you with the plumbing layout...I highly recommend that, or you can "trust" your PB to do it right!
