Add 5ppm of liquid chlorine per day until the kit arrives. Continue brushing.
When it arrives, post your results so we can figure out if there is anything else to do before you start the SLAM process.
I see you tell everyone to add 5ppm of chlorine per day. I looked under FC in the Pool Math. It only shows by ounces. How does one determine ppm? Also, jugs are 2.5 gallons/320 ounces. It's not showing in the drop down menu.
