Other than the heat exchanger, what will low TA affect in a heater?
Feb 13, 2025
13
Central Florida
First post, hope I'm in the right spot.
2 year old 3k gal salt pool, Jandy JXi 400N heater.
Service let TA crash, heat cycling got funny.
Cause discovered: palm full of metal shavings against thermal regulator.
Main filter is tinted blue, blue staining starting to appear on pool finish, assume copper coming out of solution as I return chemistry to normal.
I'm fair dinkum mechanically, hobby is maintaining and riding vintage British motorcycles.
I can get an OEM heat exchanger for ~$1000.
Are there commonly other issues than the exchanger in this scenario?
Would hate to send good money on a fools errand.
Thanks for any thoughts.
Sillius
Can we see a full chemistry assessment on your pool like,
FC
CC
PH
TA
CH
SALINITY
CYA
If you don't get a grip on the chemistry the new heat exchanger will do the same if that's the culprit.
Folks, I really appreciate the information and resource links for addressing low TA, but I'm actually looking for input regarding the damage that may have been done to heater components other than the heat exchanger itself when the TA was left to drop to <10, and no doubt the pH went acid.
I am hoping that the heat exchanger itself is the only victim here (only copper/copper clad component?) so if I go ahead and buy and install a replacement exchanger I'm not going to get any surprises and find multiple other components have been affected.
e.g. finding at some point it would have been just as cost effective to replace the whole unit.
I'm retired, so labor cost is zero. :)
Cheers!
JXI400N.
Check the condition of the TRV…
Some of the water sensors may have been damaged.
Igniter does not touch the water so low pH does not affect it.
Look at all the metal components in the water flow within the heater.
Reactions: Sillius Soddus
Of course. My bad.
I will check the water contact components when it is opened up.
But I guess we are back to my original query.
Are there heater parts other than the exchanger that tend to be affected by low TA induced pH changes?
Strategy (sort of): The heater is currently working as expected, but the amount of removed shrapnel and pool surface staining indicate damage.
I'm waiting till June or so when ambient temps here will keep the pool usable without heater.
Then bypass heater, strip and repair.
I would like to have the parts in hand at that point, so if I can determine via this group's wisdom that the exchanger is likely the only part then it will be cost effective to go this route.
If other parts are likely involved, it changes the calculus.
I don’t have a crystal ball to say what you will find in the tear down.
