Order of chemical addition
tlevy
0
Jun 3, 2015
355
Ottawa/Ontario
Hi all
Fallout from big rains:
Salt - 2700 ppm
TA - 50 ppm
Cl - 5 ppm
pH - 7.5
CYA - 30
CH - 220
CC - 0
So I need to bump salt, CYA and TA.
Is there amy issue with adding baking soda, stabilizer and salt all at once???
Cheers all
Tom
Not sure I would add any baking soda. If you do, do very little.
You can start the CYA in a sock and dump the salt in and mix it up.
Hi all
Salt - 2700 ppm
TA - 50 ppm
Cl - 5 ppm
pH - 7.5
CYA - 30
CH - 220
CC - 0
Cheers all
Tom
Yes. You don't have enough hands to do it all at once :joker:
I see no problem doing one after another. Tip: kids in the pool will enjoy mixing the salt for you.
