Not sure what is going on here. On the return line, after the heater, the pvc was getting pretty beat up. It sprung a leak, so I did a repair and noticed the pvc itself was warping/collapsing. I took photos but accidentally deleted it I guess. There was peeling layers of orange something. Like layers of it. Almost like an onion peeling but from the inside.
But going a little further down the return, I took apart some 3 way and check valves, and this is what I snapped photos of. It's so weird. At first I thought maybe it was excess glue, because if I peel that stuff in some parts, it's blue. But it's also white so that leads me to believe it's PVC? Then I look at the cap of the 3 way valve and the orange stuff is crystalline. Could it be the heater melting the pvc somehow?
Here it is on the spa return (maybe it's worse because of heat?)
Same spa return, but I peeled back some of the material, and eventually just ripped a piece out. The blue says it's glue but does it solidify into a PVC looking material?
And here is the cap of the 3 way valve, and all that orange stuff is like salt (might be salt).
Right before the 3 (or is it 2?) way valve is where I inject chlorine via a Stenner. I do have to say, The injection port gets clogged up with salt very quickly. Like a month or two and it's starting to get clogged with salt crystals.
