I took some more data today. I redid all cases (100,50/50,80/15+aerator, 80/15). I couldn't find the smaller screws to replace the actuator screws in order to take it out; therefore I played with the aerator (full on without the spray nozzle off the end) to run with a new case with the cleaning GPM that was between the 50/50 (2-notch Jandy) and the 80/15 (1-notch Jandy). I like what the data showed me so I am probably going to put in a permanent adjustable bypass between the filter output and my wall returns. It will always be on while I am "skimming" or "cleaning". I really want a 1 1/2" bypass, but given the fixtures I have, I will probably only have a 1" which means I will have to keep the Jandy open "one notch" when running the cleaning system.
I havent determined my optimum PSI yet but it is most likely going to be between 10-14 PSI. Based on the table below the GPM to the popups will be about 30, I am targeting about 25-30 GPM for the wall returns, for a total cleaning GPM of 55-60.
100% case data (no flow through parallel path) from zone 3 of my popups, this data is from today:
Pump Speed | RPM | Watts | GPM | Filter PSI | Manifold PSI | G/kWh |
70 | 2415 | 573 | 32 | 16.5 | 14 | 3351 |
65 | 2243 | 469 | 30 | 14.5 | 12 | 3838 |
60 | 2070 | 388 | 28 | 12.5 | 10 | 4330 |
Here is data from my new case (85/15 1 Notch Jandy + aerator full on) . The permanent bypass will allow me to take the aerator out of my final solution. I will probably end up operating somewhere within the range of this table, no direct correlation of PSIs but I think you get the idea.
Point that is closest to where
I want to run (85/15 1-notch Jandy + aerator, I feel like Goldilocks, the parallel flow in this case is "just right")
80 | 2760 | 1020 | 61 | 19.5 | 14.5 | 3588 |
75 | 2588 | 840 | 57 | 17 | 12.5 | 4071 |
70 | 2415 | 691 | 53 | 15.5 | 11 | 4602 |
For completeness' sake, here is the data from
(50/50, 2-notch Jandy, too much flow in parallel path, too much cGPM for system, exceeds my pump's recommendations)
95 | 3278 | 1934 | 98 | 23 | 14 | 3040 |
90 | 3105 | 1641 | 91 | 20.5 | 12.5 | 3327 |
85 | 2933 | 1366 | 87 | 18.5 | 11 | 3821 |
(85/15, 1-notch Jandy, NO aerator, too little flow in the parallel path, increased cGPM is too little for any real use)
75 | 2588 | 738 | 42 | 18 | 15 | 3415 |
70 | 2415 | 612 | 40 | 16 | 13 | 3922 |
65 | 2243 | 496 | 37 | 14 | 11 | 4476 |
Not sure why the efficiencies look better for the 2nd case where I will be running (goes against what we have talked about previously), the PSI's are even higher than the 100% case, but I think Mark is probably right about some of the measurements variability.
Another possible explanation: the aerator return path shoots onto the pool's surface without any effective back pressure (other water) against it, possibly a bad guess (help Mark???). If this is true, then I would then expect efficiency to go down somewhat when I put in the permanent bypass. In any case, I don't believe that based on the data, I will lose much efficiency by opening this parallel path.
The data for my system has consistently shown that for a given manifold PSI (whether it is the optimum or not), increased cleaning GPM through a parallel path can still operate at approximately the same energy efficiency. I have definitely figured out what to do with my "extra" GPM by using it turn on the wall returns and "swirl" my pool. I put the wall jet fixture "back on" today and that dead spot once again disappeared (from a previous post). My system may be special (short run from skimmer/drain to pump, large filter), but I suspect many systems might have room to do some adjustments to cleaning GPM, if only to optimize the energy efficiency of their system (like I didn't for 25 years).
Dodger and runboy...you both seem to be making some plumbing changes to your system. If you think there might be usefulness for you, I would recommend putting the first jandy valve after your filter directly to the valve manifold so that it has maximum available pressure to it. This assumes that you are going to open and always "run" a parallel path that you can use to send flow to the heater, chlorinator, spa/pool returns, etc. My system is like this and is definitely one reason that I am able to obtain higher manifold PSIs. Also consider a permanent adjustable bypass (mine is probably going to be a simple ball valve) around that Jandy so that flow can be fine tuned to adjust PSI for the manifold.
runboy, from your pictures on another thread, your system looks tailor made for that except for your stenner insertion point/check valve.
I've still got a lot of things running around in my head but I'll continue to work on some of it after I get back from our cruise (leave Monday). We haven't really talked about suction side and that is where I feel I still have a significant issue with my system. There are also other ways to take advantage of increasing cleaning GPM other than the way I have done it...I haven't gotten around to documenting some of those ideas.
