Hi,
We are about to install 4 MagicStream Laminars and 2 ColorVision Bubblers. They will operate off their own pump, cartridge filter and pool intake/return. The laminar deck jets will have their own plumbing runs (1-1/2") from the equipment pad and the 2 bubblers will share a single 2" pipe, splitting to 1-1/2" closer to the bubblers. For lighting, the laminars are connected to a single transformer and the bubblers will share their own transformer. Question: What is the best plumbing setup of valves (2-way, 3-way, check) and actuators/IntelliValves so that through the Intellicenter we could either run the laminar deck jets or the bubblers or both? Any excess should flow back to the pool. Possibly even select different heights for the bubblers (might be too much to ask
). The pump is an IntelliFlo VSF (probably overkill for just these features, but we were able to get it for a very good price). I know that for each deck jet we would need a dedicated 2-way ball valve to align the jet stream, but how best to design the plumbing so that the different options can be then configured correctly with the IntelliCenter.
Any guidance would be much appreciated.
