Hi! Okay. Here's my review. OMG thank goodness for TFP. Talk about handholding! haha. Ok first of all, getting the winter cover off is the suckiest part. It would have been brutal to do it by myself. Ours fell in the water which made it heavier. Maybe not so bad if it had stayed dry? The straps are on tight, for good reason, but good grief. I got the first 2 off by myself (28 total) but once you get one side, the complete opposite side is easy, you can just lift off with your hand. I was really scared after the first 2 because I had 26 more to do. Hubs came out and helped with the rest. We had a drill with the allen wrench attachment so getting the anchors flush was super easy. Our cover fell into the pool so we just laid it out on the concrete to dry and it dried out super fast. We have a 50 gallon trash can with wheels that the PB told us to get and holy moly that cover barely fit in there. Totally make your life easier and size up that thing...
The water in our pool was only like 2-3 inches below mid-skimmer level so we knew we'd only have to fill a bit. Ok so then the plug thingies that were in the pump basket, those were easy peasy. I did those. Then it was removing the skimmer gizzmo (easy) but the return plugs. oh. my. The task itself is not hard but the water was COLD like 45 degrees. So hubby did that part (lol). And he put the eyes in. Then we opened the valves and started filling the pump basket. It took us a while to figure out that the breakers were shut off and then it took us a while to figure out how to get them on. The ones in our basement were easy and labeled but we have SO many boxes outside attached to our house we were kind of flying blind. But hubs figured it out. So back to the pump, we filled that thing for hours like the ridiculous newbs that we are. We did try once during the day to turn on the pump but we were scared and turned it off after like 15 seconds. Once the water was just above mid-skimmer height I knew we had to stop. By then it was night time which was actually kind of a blessing. We turned the pump on but we were scared because we didn't want to damage the pump by having it dry. Then I got a flashlight and watched as the pump was on... I realized I hadn't given it enough time. I could actually see more and more water coming through the pipe and it was filling up then the returns spit out and we new we had success.
So today I realized that while I was a good pool owner and put a skimmer sock on the skimmer, I hadn't checked it until tonight. Whew so many leaves I think it was clogged. I dug it all out, scrubbed the skimmer (the water was freezing still) and put on a new skimmer sock.
Was it worth doing all this work? Absolutely yes. It's not only about the cost, I feel kind of proud that I know how to do it. Am I going to close my pool myself? Nope. I want to become efficient at this before I take on that task. We do plan on opening our pool from here on out as long as hubby is able to help.
You can do it!
